Changing settings to English, switches back to Chinese after restart
Old 1st Oct 2009, 10:35 am
Default Changing settings to English, switches back to Chinese after restart
So, I bought new RK27 Mp4 player, and now I have a problem.
When I'm trying to change the language settings for English, and turn the player off then on, it's like it recovering the settings and switches it back to Chinese. This problem is for all settings, not for language only.
What should I do?
Old 1st Oct 2009, 10:58 am
Shut the player down by holding down the play button, that way the settings get saved, in fact only use the play button to turn the player on or off and just leave the switch on all the time.
Old 1st Oct 2009, 11:02 am
Sorry but, what is it "play button"? I can see only "M", plus and minus. and the switcher, of course.
Old 1st Oct 2009, 11:22 am
can you post a photo of your player?
Old 1st Oct 2009, 11:42 am
I hope it's not a fake. Please tell me that this is the right one.
Thanks for your support, buddy, I won't forget that.
Edit:
Just removed the Memory Hack and found out that my player is 4GB only instead of 32GB! Goddammit!
Old 1st Oct 2009, 12:45 pm
Hi Loathly,
Now that you've removed the Memory Hack, does it resolve the problem with your player not keeping the English language?
Old 1st Oct 2009, 12:49 pm
I didn't really remove the memory hack, I get an error when using the Mp3 Disk Tool says that it can't find a removal disk although I can see it bymyself and copy things to the disk. But, I checked the capability of this thing and it says only 4GB. So, the problem haven't solved.
Old 8th Oct 2009, 6:51 am
Dump. People, please help me. I really need it. :\
Old 15th Oct 2009, 9:22 am
I'm in the same boat, tried all the formatting tools and nothing works. I like the player but changing the language and the clock not working is bugging me.
Old 19th Oct 2009, 3:50 am
I also have the same problem with the same player. Binh could you post your how to fix this issue that you were dealing with loathly. Thanks in advance
My rk27 player when changed to English, switch off but doesn't turn back on geripgeri Dead Players 0 26th Sep 2009 5:42 am
i want to change language from chinese to english fings Support and How To 3 19th Jun 2009 3:26 am
[solved] how to Change setup language back to English easydusit Support and How To 4 25th Apr 2007 5:37 pm
[solved] how to change the language back to english markker Support and How To 3 28th Sep 2006 12:13 pm
[solved] Change language from Chinese to English NoInOi Mods and Themes 8 5th Jul 2006 5:20 pm
