Rizone 16gb mp3 player language problem
Old 8th Oct 2009, 5:59 pm
Default Rizone 16gb mp3 player language problem
I bought this player off ebay and when it arrived it was in chinese and I found where to switch to english but the problem is when I turn it off and then back on it's back in chinese? What could be the problem? Theres no option to save the settings or anything like that that I could find.. Any suggestions?
Kenny
Old 9th Oct 2009, 8:56 am
1. Set the player back to English.
2. Put the player into standby mode instead by keeping the "M" button pressed until the screen turns off (coloured line across the screen).
3. Now use the power switch to turn off the player.
When changing settings ( time etc....) you must put it into standby mode first to save the settings before switching the player off.
Tags
language issue, mp3, rizone
Problem with player RIZONE RK2705 dj_chiquito General Discussion 0 13th Jan 2010 11:27 am
I just bought a 16gb Rizone MP3 player from a seller with over 3000 feedback normankev141 Support and How To 2 16th Dec 2009 7:09 am
[solved] Accidentally reset language to Chinese on Rizone MP4 player vallerieg Support and How To 7 7th Oct 2009 5:56 pm
Language problem... gtp300hp Support and How To 9 5th Feb 2007 2:23 pm
Language Problem ! Flawsey_Bee Support and How To 3 29th Oct 2006 1:31 am
