Itchee/ Rizone Player, "USB Busy, Do Not Disconnect" and then "ZZZ"
Old 20th Oct 2009, 7:32 pm
Default Itchee/ Rizone Player, "USB Busy, Do Not Disconnect" and then "ZZZ"
Hi. Well, I've bought a hacked 32 GB Itchee/Rizone Player .
I'm trying to recharge it, but it gives me "USB Busy, Do Not Disconnect" and then "ZZZ" with the USB port sign on. When this happens, it doesn't seem to charge even though the player is warm in temperature. When the USB cable is removed, the player does not turn on with the on/off swtich.
And then it gives me all sorts of things. If "USB Charge" is selected, it sometimes gives me "charging" and then "please turn off power" but it somestimes gives me "full" but the on/off switch doesn't turn it on.
I don't know when it was, but it sometimes gives me an X in a battery sign (which means it's out of battery).
In short, it doesn't seem to charge, and the on/off swtich doesn't seem to work.
I would appreciate any suggestions to make this work. I use Winsdows Vista, but have not reformated the player although I checked the player once with "system check" and the Vista repaired a problem with the disk.
Thank you.
kimkayoung
Need "private key" and "devcert template" adminn Support and How To 1 31st May 2010 5:07 am
Help removing memory hack on rizone "16" gb mp4 player bennyfy Support and How To 0 31st Jan 2010 6:24 am
Can't "unlock" 16GB 2.8" Touch Screen MP4 player javitony Dead Players 5 16th Dec 2009 8:15 pm
Dead Player - ATJ2051H - -"Sony" 1 gb "mp4&q dread Dead Players 0 4th Mar 2007 12:04 am
[solved] USB 2.0 "Full" and "Hi" speed i Zepheris Miscellaneous 4 12th May 2006 11:18 am
