RK2705 firmware extraction + ATJ2137N firmware needed
Old 20th Jan 2010, 11:11 am
Cool RK2705 firmware extraction + ATJ2137N firmware needed
Hi all, a bit of a dual question here so please bear with me:
Firsty, another member of this forum is needing firmware for a RK2705 based player (exact same spec as the one i have just purchased) so i would like to know how to extract a firmware image to upload please
(Additonal info: System info says: 'Product Name: RK27SDK)
The second one is that i got scammed on a ATJ2137N based player (16GB, but actually about 2 or 4 (forgot now)). Anyway i figured i'd try flash new firmware in hopes of removing the hack, but of course i ended up killing it lol. There is no big rush for me to get this fixed since i have a new one, but if anyone happens to know where i can get firmware for this model the specs are:
Proccessor: ATJ2137N
Board ID: ZX-8058R-TLSK-T-V1.2
(Under board id: 4609 20090828 H)
Cam ID: XHB 7678F
Memory Type: Hynix
Any assistance in either of these would be greatly appreciated and thanks in advance ^_^
- kuronyu
Old 20th Jan 2010, 11:35 am
Here is the rk2705 info:-
Firmware Extraction for new Rockchip RK27xx series players.
Old 20th Jan 2010, 1:42 pm
Thanks knob!
I have stored a copy of the firmware now (and also modded some new wallpapers into it (yay!)), Many thanks
Old 27th Jan 2010, 5:27 am
kuronyu, if it possible, upload your full firmware please!!!
I've the fully identical but noname china device (Proccessor: ATJ2137N, Board ID: ZX-8058R-TLSK-T-V1.2, Cam ID: XHB 7678F, single difference - memory type, my device has chip by samsung) which departed this life after unsuccessful formatting.
Old 27th Jan 2010, 8:18 am
I would love to upload the firmware for it, but sadly i still havent managed to find any for this player. The only firmware i have is the one i extracted from my new rockchip based player.
I am still trying different firmwares for similar players in hopes that one will work. If i find a working one i will let you know
The main problem i am haveing at the moment is that when i try to flash, the device re-sets itself. I hope i havent damaged it to the point that it wont flash new firmware anymore :/
Old 28th Jan 2010, 2:50 am
Oh, its sadly...
But i'll be waiting for your news with belief and hope!
And if i'll be able to find working firmware - i'll inform you immediately!
Apropos, which kind of programm tools you use to extract firmware?
I ask because i already tried to use: s1fwx_v30, s1fwx_v33, s1res_v19, s1clone_v21, s1res_v41, MP3_Player_Utilities_v4.18 and MP3_Player_Utilities_v5.09. And i couldn't get access to extract firmware nor with one of them. May be these programms do not support the new ATJ processors... Or, that more probably, i've got a problem with ADFU drivers. My device was not defined by system nor with one of source ADFU drivers (i've got 5 different versions of drivers). It was connected with PC only after i've changed the adfu.inf (i has manually added my device's PID).
Tags
atj2137n, rk2705, rk27sdk, zx-8058r
Visual Land V-Tap Board ID: CR43TFTPMP V1.4, Processor: RK2705 firmware Obaid_Saab Dead Players 0 26th Dec 2009 11:25 am
4 Gb mp4 firmware extraction CoYoTe Dead Players 1 29th Mar 2007 4:59 am
firmware extraction paolino70 Support and How To 0 20th Dec 2006 7:52 am
Firmware extraction broose Support and How To 1 4th Dec 2006 5:36 pm
Firmware Extraction Parsec Support and How To 1 15th Nov 2006 8:31 am
