Help removing memory hack on rizone "16" gb mp4 player
Old 31st Jan 2010, 6:24 am
Lightbulb Help removing memory hack on rizone "16" gb mp4 player
hello out there, i was hoping someone could helo with the rizone mp3 player.
I have done the test and have got that the memory is 1.8gb only. But still i have tried and the hack removal
ways that are listed on MyMPx but they do not work.
When i use the flash program that is mention to do the low level clean i cannot cause when i selete "physical " drive or wateva it doesnt register the mp3 then. i can only do it on "logical drive".
Iv also tried it in dos with "mkdosfs" and that way didnt work either.
I think it must be a newer hack i only recieved it in Jan 2010. please someone with any help so i can get some use out of it
i would very much appreciate it.
Also it has a "ROCKCHIP rk27xx chip in it.
thanks again.
Bfy.
Tags
16gb, firmware, hacked memory, rizone
How To: Removing Memory Hack admin Support and How To 128 1st Dec 2013 2:35 am
Unable to remove memory hack from "shuffle clone" Mr. Frog Support and How To 3 7th Feb 2010 3:09 pm
How do I remove the memory hack from "8gb" 4th gen Nano clone? helloha Support and How To 11 10th Jan 2010 11:41 am
Problem with " Removing Memory Hack" WordsVsPain Support and How To 3 10th Jul 2008 1:29 am
