5th Apr 2010, 9:52 am
Pmp Slide mp3 reproduction/play problem, help me.
Hello.
I bought a PMP Slide with 4 GB with expansion into 4gb with SD CArd.
Mine is like this:
Mine says Sony in the right and is Orange color.The problem is: when I have more than 109 mp3 songs the rest plays wrong like pause every second,(01 until 3 playes so a silence, then the next second plays and the same ) cut after 3 seconds. I formated but the same problem persists, the files are not corrupted.always after 109 song the same problem appears.
What can be a solution? Some told me buy a SD Card but I don't know. Help.
PS:Other problem is the Tv Out don't work,some told me can be the cable is bad, but I think the Pmp is bad about it.
