Little help with my hacked mp4 player!
Old 23rd Apr 2010, 9:00 am
Question Little help with my hacked mp4 player!
Hello, all! I'm new to this forum and i wanna ask for some help . I got a hacked mp4 player claimed to be 8GB but the real memory is only 2GB. I have tried many things i have done many formats but even if i made the size back to 2GB the player still got problems with playing mp3 files, displaying pictures etc... always getting "disk error" maybe something went wrong? But i can't find a firmware for this mp4 player. So i will post some pictures of the mp4 player + some pictures of the chips inside... maybe if someone have more knowledge and have fixed it please help me . Tnx in advance.
1. http://i39.tinypic.com/2z6fn9y.jpg
2. http://i44.tinypic.com/33kun11.jpg
3. http://i44.tinypic.com/vo7o1i.jpg
4. http://i39.tinypic.com/rqw21t.jpg
P.S. Information from ChipGenius.
Code:
Device Name: +[I:]+USB Mass Storage Device(ACTIONS HS USB FlashDisk USB Device)
PnP Device ID: VID = 10D6 PID = 1101
Serial Number: 4512482ADF0FE
Revision: 2.00
Device Type: Standard USB device - USB2.0 High-Speed
Chip Vendor: Actions(??)
Chip Part-Number: ATJ211x
Product Vendor: ACTIONS
Product Model: HS USB FlashDisk
Tools on Web: (N/A)
Old 24th Apr 2010, 2:09 am
Its seems i can't remove the hack. If i use MP3 disk tools to format i get 2 partitions, and all options of the player are working, but i need to put the files on the 17mb partition... Can someone help please?
Old 29th Apr 2010, 9:11 pm
It's a Series 11 device... sorry, but currently we have little understanding of them. Please be patient, we may get it eventually.
Old 30th Apr 2010, 8:32 pm
i have bought, unhacked, and sold at least 2 of this player
it is ak2025 is it not?
run this process and it will be fine
ChkFlsh method (revised)
I edit my p o s t s a lot.
Hacked Anyka PMP Mp3 player please help Superrob3 Support and How To 7 19th Mar 2011 11:03 pm
Hacked player said 16, really 2. jgrayson_au Bad sellers/Blacklist 4 16th Jan 2010 6:53 am
can someone tell me if this is a hacked 8gb player? dittoLIVE Support and How To 1 5th Apr 2009 12:26 am
Hacked 4gb Player Swater Support and How To 2 1st Jan 2007 11:11 pm
I have a hacked player.. Dean786 Support and How To 5 30th Dec 2006 12:03 pm
