Problem with player
Old 5th May 2010, 6:37 pm
Default Problem with player
I have a 2.8" touch screen MP3/4 player 8GB. It comes from ANYTS Store. I want to find out what firmware to use to update it as I cannot seem to play videos on it. The player says the software is TV802 MLC V1.2.3A, hardware is S308A V1.3
Old 24th May 2010, 8:53 pm
Lightbulb
maybe it's mp4 player, so you should play mp4 format vedio. if you play the avi and rmvb formats, it can't play them. so you must convert these format vedios to mp4 format which your mp4 player can support.
check whether the problem is above. and when you vonvert the format please remeber set up the vedio size of final format.
Old 25th May 2010, 3:38 am
Do you have a SAMPLE video on the player?
Can you send us a URL link to where you bought the player from or was it from an actual store?
What you could also do is download a whole lot of sample .avi video files from here: http://mympxplayer.org/sample-rockchip-videos-with-different-screen-sizes-df1014.html and see if they play on your player.
If you can post more information about your player, some photos etc... that would be more helpful.
Problem with S1 Mp3 Player sebaspo Support and How To 3 23rd Mar 2007 3:03 pm
amv player problem katsaflias Support and How To 0 3rd Nov 2006 9:02 am
problem with my mp4 player. lordik Support and How To 1 6th Oct 2006 3:26 am
problem with my mp4 player wind Support and How To 3 22nd Apr 2006 10:32 pm
