How to extract the firmware
Old 8th May 2010, 2:21 am
Default How to extract the firmware
Hi, my mp5 player is still new and working, but due to my bad experience with my old mp3 player, I'd like to know how to extract the firmware in case of any future failures. My PC (Vista) recognizes the player as a Rockchip USBDisk. The system information I see is: Major version ID 1.1 and Firmware date is 090518.
It's 4,3" and 8Gb if it matters.
Thanks in advance
Old 8th May 2010, 9:08 am
try this, it often works.
Firmware Extraction for new Rockchip RK27xx series players.
Old 8th May 2010, 9:59 am
After using 2 programs which I found in the forum the results are: Look at the 3 attached images. Can I still try the program you offered me KNOB or not? Thanks!
Old 8th May 2010, 10:13 am
yes. in spite of what chip genius shows you player looks like a rk27xx series, try the rkusb.tag method.
good luck!
Old 8th May 2010, 12:38 pm
WIZARD's Avatar
Exclamation
But "Chip Part-Number: RK2608" !
I think that this method will not work.
But you can try : in this case it's not dangerous for your player,
just a small, useless (for you) file.
Try to play !
How to extract firmware 9 and up. Multiplayer Support and How To 9 13th Sep 2009 4:07 pm
How to extract firmware 9.1.53 MXP Support and How To 3 12th Feb 2009 5:35 pm
How to extract 9.1.52 firmware nywww Support and How To 16 19th Mar 2008 6:16 am
Can You Extract A firmware 9.0.48 baistosh Support and How To 1 4th May 2007 8:40 pm
Cant extract firmware zetski210 Support and How To 8 21st Dec 2006 6:06 am
