Mp4 Player disk error problem
Old 23rd May 2010, 12:44 pm
Default Mp4 Player disk error problem
Hello,
I have mp4 player. My mp4 player was infected. I've formatted. My current problem mp3/mp4 not play. Disk error says, but the radio is playing. My mp4 player firmware version: MP4 PLAYER CBD CO., LTD 2009-07-28 9.5.54. What is the solution? Please help me
Old 24th May 2010, 12:13 am
How To: Removing Memory Hack
Old 24th May 2010, 1:41 am
Reply for thanks,
Computer (Windows 7), the disk is formatted "fat32".
Old 24th May 2010, 4:12 am
What memory size is your player?
Did you try following the steps in the "How to remove memory hack" above? Did that work?
Old 24th May 2010, 4:48 am
Memory size is 8 GB. No. I did not try. How to remove memory hack? I don't know. How?
Old 26th May 2010, 1:18 am
Read here: --> http://mympx.org/forum/support-how/35010-how-removing-memory-hack.html
Old 26th May 2010, 9:03 am
Hello, this method of unhacking players that has been suggested to you is almost obsolete. It never works for me anymore, because the program cant recognize the player anymore for some reason( i don't know if this is intentional by the hackers or just a problem with my systems. However there is another method which does basically the same thing but easier to understand whats going on. Try this guide to unhack and let me know if it works.
ChkFlsh method (revised)
Please detail your findings.
I edit my p o s t s a lot.
[HOWTO] Remove DISK ERROR! / Error format etc.. on AK2025 Errorboy Support and How To 16 30th Jan 2010 3:28 pm
Disk Error or disk is empty message maclover201 Dead Players 0 19th Aug 2008 10:29 am
problem with my ipod 1GB . "disk error" djamel Support and How To 1 2nd Feb 2008 7:22 am
my 8gb lg mp4 player - disk error stonyboyjr Support and How To 1 27th Aug 2007 4:40 pm
MP4 player disk error xplorer101 Dead Players 4 14th Mar 2007 7:50 am
