Help to identifiy this RK27XX player
Old 28th May 2010, 2:21 am
Default Help to identifiy this RK27XX player
Firstly, I tried to upload photos to gallery but they did not show up. Maybe I did something wrong but be patient, please, I am not a geek. I uploaded them here:
I have some questions- can you help me to identify it? There are no screws, when I turn it on there is the only system information RK 27XX. There is no type of identification in manual either.
I am afraid of only 1 thing- how to change battery after years when it will be needed, in general is it possible for a reasonable price?
Old 28th May 2010, 5:34 am
Hi, knowing that it's a rk27xx player is maybe as much as one can. For the battery, if its not exposed/meant to be changed by the owner you have to open the player in order to replace it. I think any 3,7V battery with as many Ah as you need will do it. Changing it in this case may require to unsolder/solder two wires from/to the board.
Old 28th May 2010, 8:01 am
Hello!
Thank you for you prompt response!
Hi, knowing that it's a rk27xx player is maybe as much as one can. - You are suggesting that these Chinese mp3 players have no more known distinction that can help anyone later to update firmware or what? I am just asking to be sure. Is that the case that they do not have a name and generation as ipods? Or there are thousands of different rk27xx that use basically the same firmware?
About that battery thing- how would you open that player, when there are no screws? just curiosity, I will let it do at some service center
One more time, thank you!
Old 31st May 2010, 2:18 pm
hi i'ver got the same one. is there any update to watch pdf's ???
thx in advance
problem with my rk27xx tanghola Support and How To 1 9th Apr 2010 6:42 am
problems with my rk27xx tanghola General Discussion 0 7th Apr 2010 5:54 pm
RK27xx MKV? Kaizoku Support and How To 1 5th May 2009 4:30 pm
Rockchip RK27XX Help! ALP1987 Support and How To 8 12th Oct 2008 8:36 pm
