Need help on my player
Old 19th Jun 2010, 6:22 am
Sil Sil is offline
Default Need help on my player
Hi guys I'm having problems with removing the memory hack on my player.
I've followed the instructions on the sticky how to but I still can't use the player to it's full capacity.
I've tried the disk tool and from following the instructions I can slide the partition slider upto 2007mb
Here are the steps that I did:
1. Open Disk Tool, and set format type to low.
2. go to partition tab and slide the slider all the way to the right.
It says in there the following data:
Disk Total Capacity: 2024
setting encrypted capacity 2007 MB
3. Click Start and Ok when finished
4. Slide the slider all the way to the left
disk tool is still saying Disk Total Capacity 2024 MB
5. Click Start and OK
But after doing this, I still end up having only about 470MB of usable disk space. Am I missing anything in here?
Opened the player and saw two large chips labeled as:
1. AK2025
SA90WAC 0J5
2. 04G08W012
1002
Hope that helps in your diagnosis.
