16 GB MP4 froze. Does not work.
Old 26th Jul 2010, 8:11 am
Unhappy 16 GB MP4 froze. Does not work.
I bought the device from ebay. Device to create a new folder outside of the standard folders that I copied into the folder of image files. After the file has been corrupted files, I noticed when I want to watch. The other half of the image is properly part of the picture was distorted. Turned to a very strange character filenames. File names changed automatically on the device itself. I think I turned off the device improves. That did not work then the device again. I want to run the device at the screen I see the WELCOME text. I reset a few times. But the problem was not solved. I think I delete the files from the device installed in such devices will not work. Computers do not perceive it. So I can not connect to the device with the computer. How can I solve this problem? Many thanks in advance for your help.
Old 6th Aug 2010, 12:24 pm
My player looks just like yours, also was supposed to be 16GB, but, as a lot of these players are hacked memory, it is only 1.65 GB free memory. I believe image files are limited to 5MB size. If you write to much to the memory (over 2GB) it corrupts the files and sometimes the file names.
You should copy the directory files and directories to your computer before you format and then copy them back later.
You might be able to see the memory with 'Active Partition Manager' free. It did work on 3 of my players.
Download the free version at - -http://pcdisk.com/download.html – also download the PDF file.
Old 6th Aug 2010, 12:38 pm
But my device does not work. During the first start of the text on the screen is only WELCOME. No other device does not respond. Device or a computer linked to a time spent wondering the normal operation will delete all the files, but I could not. The second stage of the event memory correction. Work the first stage of the device. As the hardware for that device to clear the memory needed. I think. But I do not know how to do it. If anyone knows I would expect to share. Thank you for message.
froze up to an hour glass screen chrystal0925 Dead Players 7 4th Nov 2008 9:38 am
My MP4 Doesn't work maungphyowai Dead Players 3 18th Aug 2008 3:22 am
s1 - Upgrade doesn't work Katzenfreund Support and How To 0 26th Jul 2008 10:25 am
3.5.37.... any will work? mgatskie Support and How To 1 17th Mar 2007 10:35 pm
Videos don't work! Bochi Video related 4 15th Sep 2006 5:41 am
