-   -   NEED HELP on AJ282_v5 player stuck on "Loading......" (http://mympx.org/forum/support-how/45621-need-help-aj282_v5-player-stuck-loading.html)
de.das.dude 6th Oct 2010 10:38 pm
let me start by saying i got this off one of my dads workers.
the problem is that when i open the player. it goes to Loading...... and gets stuck there.
the specifications are:-
PCB: AJ282 v5
Memory: 8GB Hynix HY27UT088G2A
fLASH: 48lc8m16a2
COU: Sunpkus SPMP 3052A-HL171
hOW DO I FORMAT this??
is this dead?
note i dont have a SD card.
i have a USB-mini USB chord form mu nokia3110c, i think that will work right?
but my Windows 7 enterprise x64 isnt detecting it!
