Problem with Mp4 - Need Help Please!
Old 8th Mar 2011, 5:09 pm
Default Problem with Mp4 - Need Help Please!
Hi everyone!
I have a problem with my mp4. I bought like an year ago and it originally should had 8 gb but I did that memory hack thing and it turned out to have less than 2 gb... But it was working good and I have never had any problems with it...
But today I turned it on and tried to acess the music folder and it appeared "Disk Error".. It had 322 songs in itand only 12 mb left.. I tried to format it and the memory went to the original 8 Gb. So I did that "Memory hack" stuff with the Mp3 Utilities Tool and it didn't work. As an alternative I did the CheckFlash thing and it went to the normal 1,8 gb that I put as the partition. I formatted and thought everything was ok. So I turned it on and it still says that has 322 songs ans the Disk Error still appears... I really don't know what to do... Please help me.
EDIT: Now i formatted it again some times and now it appears 0 songs and 0 mb free... But the error "Disk Error" still appears. I don't get it.
Old 23rd Mar 2011, 11:58 pm
No one?? I really need help with this.
Old 24th Mar 2011, 9:05 am
Yeah, the people here arn't paid to help others, so they get to it when they get to it.
What I would recommend you do, is run a disk check on your player, to check for errors bad sectors. Link bellow describes the process...
How to: Perform a scan disk and repair bad sectors
PS: The admin who created this second website, really needs to go through the HTML code in the knowledge base links, to correct the text display issues!
