Battery issues...MP5 player...Solved
Like Tree1Likes
  • 1 Post By stepher
Old 1st Jul 2011, 3:16 pm
Thumbs up Battery issues...MP5 player...Solved
Hi all,
I was here (MP5 Battery issues, clock-calendar function) about 2 years ago regarding my MP5 player and some things I needed to figure out (Originally I wasn't sure if the chip was a 2705 or 2706. After taking another look, I'm fairly certain it's a 2705). I've got some of it squared away and then got distracted before I could spend any more time on the battery issue. So, I'm back to tap into the wonderful collective wisdom that exists in this forum
Still not getting the amount of play time I would expect (from what I hear others are getting), and it may be getting worse given the aging of the battery. I finally took some measurements of current draw under operating conditions (display on/off, music/no music). Here's what I found:
1. Display off, no music - 39mA
2. Display off, music playing - 82mA
3. Display on, no music - 115mA
4. Display on, music playing - 148mA
My Conclusions:
A. The display draws quite a bit when on. Even so, given the supposed A-H capacity of the battery (see below), I should still be getting 3 hours and a bit more of play time, (520/150 ~ 3.5). With the display off (or short on-time, where it's set now), I should be getting closer to 6 hours. Not the 10-15 some people have told me, but certainly better than what I have been getting (1-2 hours).
B. Playing music adds about 40mA of loading.
One other thing I noticed is that when I do a soft turn on, while the button is pressed, I get a fairly high current draw (~130mA). When I let go, the draw goes back to normal?
So, do these readings sound normal to folks?
I may very well need to replace the battery. I do not know if it's NiCad or Li-Ion (makes a difference in charging methods). Physically, the battery is 2" x 1-1/8" x ~1/8" thick. On 1 side, there are 2 printed lines. The first is "XXSUYUEN" or "XXOUYUEN" (where the "XX" are letters I can't read) followed by 043048SP (part no.?). Below this is "7V 520mAh 09A". The "520mAh", IMO, would mean 520 milliamp-hours in tech-speak. The "7V", I'm not so sure of. Taking a direct voltage measurement on the battery, I get a nominal 4.0 VDC, give or take depending on whether the unit is on or not and/or has the charger plugged in. BTW - The charger that came with this unit is 5.5VDC @ 500mA output, so I doubt the "7V" on the battery means 7 VDC.
And any ideas where to find a replacement? I'm thinking about going to an external battery-based supply (using more standard rechargeable LiIons), but that kind of impacts the whole portability concept.
Anyway, appreciate any help or insight anyone has.
Thanks and cheers...Steph
Old 2nd Jul 2011, 12:15 am
This will be li-on 3.7 volts for sure. get the biggest mAh capacity that will fit in there.
look at this thread here.
Rockchip Player Battery Swap
Old 2nd Jul 2011, 10:20 am
Thumbs up Battery issue, MP5 player...Solved
Thanks for the feedback and link. I did a bit more research and found an article on wiki (Lithium-ion battery - Wikipedia, the free encyclopedia) that explained some things for me. It's fairly tech-y, but has good info about the aging characteristics of Li-Ion batteries.
Since I bought this in China (with a friend who speaks Mandarin), I know it is truly a 2GB MP5. What I don't know is how long they had it in their stock. If it was there for over a year, then the battery already lost 20% of capacity, maybe more. Now, 2 years hence, and capacity has prob'ly dropped to 50% or less. Prob'ly time for a new battery anyway (saw the same thing happen with my cell phone I have an electronics background, so I can prob'ly use a battery with contact points (instead of wires) and solder (carefully!!) to the contacts.
In my unit, length and width aren't critical. However, thickness is. Prob'ly some margin, but not much.
After thinking more about the battery, my belief is that it does say 3.7V on the 2nd line (before the 520mAh). It looks like the "3." never got printed. This area is located right below the "XX" I couldn't read (mentioned in my previous posting), and I can see how the "3." could have been left off.
Thanks again for the help....Steph
Old 3rd Jul 2011, 12:43 am
Open circuit voltage of around 3.9 - 4.0 volts sounds about right when testing one of these batteries using a multimeter, then it drops to about 3.7 on load.
cheers knob
Old 3rd Jul 2011, 2:08 pm
Default Battery issues...MP5 player...Solved...Update
Well, I found a cell phone that isn't in use and "borrowed" the battery out of it. It's rated 3.7V @ 1020mAh, double the current capacity of the MP5 battery I believe has failed (and similar in size...yay! I'm in the process of testing it and all seems to be going OK. Did a full (hopefully) charge and have been playing uninterrupted for 2+ hours so far. Battery level shows still mostly charged. Prob'ly "borrow" it permanently (cell phone has a broken micro-USB connector so I can't charge the battery in it
Cheers...Steph
Originally Posted by stepher View Post
Hi all,
My Conclusions:
Old 27th Nov 2011, 6:24 pm
Default Solved...Final Update: Battery issues...MP5 player
Hi all,
Back in July (See below and Battery issues...MP5 player...Solved) I had figured out my battery problem and knew I needed another battery. While I didn't do an exhaustive search, I discovered finding an exact replacement at a reasonable price was not going to be impossible, but certainly close. As I mention below, I considered using the battery out of an old cell phone, but it was nearing the end of its life and I tried to take it apart to see if I could get it to fit. Unfortunately, that made this battery unusable. As a result, I decided I would look for another commercially-made battery I could use as a replacement.
Here is my journey, now complete......
In my continued search, I also decided to find a larger capacity (settled on 1,100 ma-Hrs, 2x the original battery) to increase expected playtime. This resulted in 3 concerns/challenges:
* Fit: While there was some flexibility in the length and width, even the thinnest commercial batteries were thicker than the original and would not fit into the player without making modifications.
* Connections: The original battery was manufactured with wires as connections. Any commercial battery I considered had contact points and I would have to figure out how to make the connection.
* Charging: From what I've read, Li-based batteries require chargers with some level of intelligence. Without details about the charging hardware and control s/w, I didn't know whether the MP5/MP3 player charger had enough smarts to handle a battery with a different capacity. I would have to do a test.
So, I finally got motivated and started to look at what mods I could do to use a different size battery.
* Fit: I knew I'd have to modify the existing metal back cover to make room for the battery and then create a new back cover to hold the battery in place. My first thought was to cut (using a rotary hobby tool like a Dremel (tm)) the metal back cover and create a "battery box" by bending "tabs" in towards the circuit board. I initially abandoned this idea becaue I would have to use hand tools (pliers, cutters, etc.) to bend the tabs and was concerned about accuracy of bending 1-1/2" long tabs and how this process might distort the back cover (It was already a really tight and small-toleranced fit).
My next idea was to build a battery box using double-sided PC material and then figure out how to mount and secure this box inside the MP5 player. Two advantages to this was that it meant no bending, just cutting the back cover and using a "tab and slot" method to secure the battery box and I also figured that using PC material might allow me to create some sort of contact arrangement (possibly using stuff from an old cell phone) for connecting to the battery. My concern here was that the battery box, while easy to make and fairly easy to mount, would take up a bit too much room inside the player.
So, before I actually did anything, I set it aside and thought some more. A couple of weeks later I had a D'oh!! moment
I realized I didn't have to cut 1-1/2" long tabs to make a battery box. I only needed enough "sides" to keep the battery in place. I designed the tabs to be a manageable 1/2" wide and was able to bend and adjust until the battery fit very nicely. I ended up with 2 tabs on each side of the battery and one tab at the top and bottom (with the top offset for access to the battery connections). Once I had the battery fitting well, even tho I filed down any rough edges I could find, I added heat-shrink tubing to the side tabs to prevent any rubbing of the battery paper wrap (the battery top and bottom had thick plastic support pieces, so I didn't worry about them as much).
I also had to make a new back cover. The folks at Tap Plastics here in Silicon Valley were very nice. I went over and picked out an 1/8" (actually was 5/32") thick piece of scrap plastic. I went to pay for it (~$1.00) and since they were a bit busy, they just waived me off and said don't worry about it. It was about 1' x 1' square of plastic so I had enough to cover a few mistakes (and experiments).
It was a fairly straightforward process. Cut to size, add screw holes (and countersink), and drill out for the speaker and mic (I had no plan to use these functions, but I expect they helped heat escape during charging time). I ran into a couple of snags, tho. The battery was thicker than I thought and it stuck out beyond the original back cover. I essentially had to sand/mill the new plastic cover over the battery area to allow the new cover to sit flat. Also, because of where the battery was located in the player, there wasn't enough room on one side for a screw. To solve this, I found a piece of thick right-angled plastic, cut a slot in the new plastic cover and glued in the RA plastic piece as a "catch" to serve as the 3rd screw. Then I formed a slot in the original cover (between 2 tabs of the "battery box") where the "catch" piece would be inserted and hold down that side of the new cover. It took a bit of effort and a couple of scrap pieces to make this work right.
To make it look nice, I did some molding and forming using the rotary tool and made the new cover lines follow those of the old cover. Actually turned out pretty nice.
* Connection: I chose to do what the manufacturers warn you not to do, and what I wouldn't normally recommend anyone to do. I soldered wires directly to the battery terminals and then soldered those to the MP5 board (as was the original battery). To do this runs the risk of reducing the battery life, destroying the battery completely or, in the worse case, having the battery blow up. I used a fine tip and set my soldering iron to the lowest temp that would melt solder. I also kept contact between the iron and the battery to the bare minimum so as not to overheat the battery. I'm happy to say the battery seems to be fine.
I had considered some kind of spring-loaded connection arrangement but decided it would be hard to implement and I had no need for a consumer-style of battery removal/replacement access like in cell phones (possibly for SIM card access) or PDAs. If the battery needed to be removed/replaced (and hopefully wouldn't for at least a couple of years), I would be the one to do it.
* Charging: So, now I have the battery installed with a new back cover and I now needed to test it. I had taken new measurements since my previous posting and found I had an error in the original results. Using the new values and factoring in my estimation of the low-battery shut-off point, as well as having the display enabled occasionally during use, I calculated about 16-17 hours of actual play time. I charged the battery up (using what the MP5 battery indicator showed) and then set it to play music until it shut off. I did occasionally enable the display as part of the test and to check battery level. I ended up with over 16 hours of play time. Not bad at all (I went back and calculated what the original battery should have provided and that was about half the play time I now have). I guess the MP5 player charger does have the smarts.....
Needless to say, I'm very happy. Everything works fine and I increased the thickness of the MP5 player a mere 1/8" (still thin enough to fit most anywhere). I bought a new pair of in-ear earbuds and am amazed at how much better the sound is than with the original earphones (well, duh!!!
Re: Photos...
1st photo shows the modified back cover with the "battery box" and battery out. The white line on the left side of the new back (black) cover is the "catch" piece (See photo 3 for better detail). The scrape marks on the new back cover was my "sanding/milling" to make room for the battery height.
2nd photo shows the battery in place. Nice cozy fit.
3rd photo is a close up of the catch and slot arrangement. Note how there was no room to make a screw hole.
4th photo (sorry for blurriness) was meant to show how the battery sticks up beyond the existing metal back cover. You can see the 1/32"-1/16" added height of the battery coming out just above the metal back cover.
Last/5th photo shows the unit completely assembled. You can see how I tried to make the new back cover follow the pattern of the original cover (note the inverted corner pattern).
Cheers...Steph
Cheers...Steph
Binh@MyMPx likes this.
Last edited by stepher; 27th Nov 2011 at 6:42 pm. Reason: Update phots and add descriptions in posting
Old 28th Nov 2011, 11:59 pm
Wow, nice work on your modified player!
Thanks for sharing this and also sharing photos as well as the very details steps. Much appreciated and good work!
Old 29th Nov 2011, 8:49 pm
Bihn,
Thanks for noticing
With the cover off it's easy to see that I worked with hand tools to do this mod. The new plastic back cover did turn out OK (noticed in the photo it could use a bit more fine sanding on the near edge and does hide the roughness of the mod very well.
I still think it would have been way cool to create and install a separate battery box with some sort of contact arrangement for (rather than soldering to) the battery. I expect if I had the patience and motivation, I could have done so, but it still would have been overkill.
Cheers...Steph
Old 29th Nov 2011, 11:55 pm
You've shown a LOT of patience by doing all this and also sharing it with us all.
Have you thought about putting some nice artwork or something on the back of the case to customise it even more?
Any other plans after this?
It's a pity that all the manufacturers cares about is the cheapest way to get the players produced and sell cheap. If they put in as much effort into the player as you have, (the battery would be very good for starters), or even just a little bit more effort, I'm sure they would produce a very well produced player that would be actually really good.
Old 30th Nov 2011, 9:30 am
Default Solved....Final Update: MP5 Battery problem
Hi Binh It isn't obvious from the photo but the new plastic back I formed is smoothon one side (facing the battery) and patterned (as in unsmooth) on the outside, so it has a kind of finished look. Never thought of adding any artwork design. I'm happy just as it is. Tho, I'm always open to suggestions. This will be the extent of any mods for this unit. My main concern was to fix the battery issue and that gave me the chance to extend the playing time. Nothing else I can think of. When I had it apart, I did notice there is an empty place on the circuit board for an additional memory chip (would increase from 2GB to 4GB) but I'm not sure it's worth the cost. I bought this unit mainly because it has a MicroSD memory slot (up to 8GB). So, I just pick up additional chips, load 'em with music and plug them in. Works for me I agree about the mfg quality. But then, these units weren't built for design beauty and/or quality. Mainly for cost and profit. Cheers...Steph
MP5 player battery problem Trefayne Support and How To 0 22nd Nov 2010 4:23 am
My new RK27sdk MP5 PLayer - help trej Support and How To 1 8th Jul 2010 2:05 pm
About MP5 Player Rockchip joey90 Support and How To 1 1st Nov 2009 1:01 am
MP5 Battery issues, clock-calendar function stepher Support and How To 7 22nd Jun 2009 9:17 am
help mp5 player newflycom Support and How To 2 5th Mar 2009 4:25 am
