Need help identifiing an MP4 player
Old 28th Nov 2011, 1:04 pm
Default Need help identifiing an MP4 player
I have an 8gb 4.3 touch screen player from a Chinese manufacturer that came in a black cloth bag doesnt have any cables or directions. I powered it off first and got a message on the screen of goodbye then slid the switch to on and it powered up. I went through some of the data that was stored in the player. There was two music entries from 2007 two movie trailers Tranformers 2 the player has two headphone jacks a TF SLOT on off switch USB port all on one end. A small onboard speaker in back opposite the switch end of the player.Front is gray thin line trim with 1/4 inch screen border in black screen is gray when off. The back is silver has one tiny phillips to remove back cover for battery replacement. The player operated fine for ten minuites or so I powered it off and the next day it would not work and still does not. If there is a way to charge this and make it work again or if it can be fixed please post any knowledge or help. troyj63
Old 30th Nov 2011, 1:45 am
try plugging in the usb to your pc, and give it a charge.
if you dont have a cable get one, they are cheap
