-   -   Problems with connecting to PC rk27sdk (http://mympx.org/forum/support-how/46166-problems-connecting-pc-rk27sdk.html)
stan88 29th Dec 2011 10:01 am
Hi, i have rockchip player rk27sdk version 2.2 type 080722 2.5 years old, last year when i connect him to PC he appears on a couple of seconds (1 - 4 sec) in a safety remove device :
RockChip USBDISK UserUSB Device
RockChip USBDISK SD USB Device
and turned off and begin charging the battery.
He connect normally to PC only if i put windows in save mode :confused:, others functions works fine :D.
I dont do anything with firmware, only change manually icons and backgrounds but it was in the first month after purchase.
I thought that something with cable or player slot for cable, but why then he connect hormally when windows in save mod ???? :confused:
stan88 15th Jan 2012 5:47 am
i still wait
