Problem, which I was not aware of...
Old 16th Apr 2012, 3:58 pm
Thumbs down Problem, which I was not aware of...
hello guyz.
The situation is as follows, i have bought an mp3 from a market in Latvia, which was a copy of Ipod nano, 8GB.
I started receiving errors of format, on it when played recently added songs...
started to look in to this matter, came across the memory scam, right now i feel really dissapointed.
Tried out the software which suggests to see how much space the mp4 has.
Results:
Warning: Only 7961 of 7962 MByte tested.
The media is likely to be defective.
3.8 GByte OK (8093568 sectors)
3.9 GByte DATA LOST (8210560 sectors)
Details:0 KByte overwritten (0 sectors)
0 KByte slightly changed (< 8 bit/sector, 0 sectors)
3.9 GByte corrupted (8210560 sectors)
0 KByte aliased memory (0 sectors)
First error at offset: 0x00000000b70f0000
Expected: 0x00000000b70f0000
Found: 0x0000000000000000
H2testw version 1.3
Writing speed: 6.21 MByte/s
Reading speed: 10.7 MByte/s
H2testw v1.4
2nd time
3.8 GByte OK (8095616 sectors)
3.9 GByte DATA LOST (8208512 sectors)
3.9 GByte corrupted (8208512 sectors)
First error at offset: 0x00000000f70f0000
Expected: 0x00000000f70f0000
H2testw version 1.3
Writing speed: 6.25 MByte/s
Reading speed: 10.6 MByte/s
H2testw v1.4
So to make things clear. I was scammed, and this mp4 has about 4 GB memory, and the rest is not recoverable right?
If that so, I will probably rage and go to the store...
Help would be much appreciated.
Best regards Sergio.
