Help me identfy actions player
Closed Thread
Old 29th Aug 2013, 6:48 am
Default Help me identfy actions player
Hi I'm a newbie here. I want to encode some AMV video for my daughter's new player but I can't.
The supplied SW "AMVFairy" fails to load (transcodedll error)
AMV converter from this site's excellent utilities results in FORMAT ERROR! on the player
The instructions specify an uncommon 160*128 size, I managed to produce some, but FORMAT ERROR!
The sample files supplied on the unit play OK, they are 160*120 16fps AMV and I can't tell how the ones I make are any different.
Anyway I've searched around and I'm not getting anywhere as this player is generic and doesn't have a manufacturer or model number, It coes up in windows as ACTIONS_HS_USB_FlashDIsk2. Firmware version 1.0.04 AS211A_V1003
Can anybody tell me what to search for so I can make a compatible video?
I'll upload a pic.
Thanks in advance
Old 1st Sep 2013, 1:29 am
I thought I'd update my thread in case it's any help to anybody else. I finally encoded AMV that works at 160x120 16fps using 4videosoft amv converter, so I'm clever dad again (which I like), mind you I never got to the bottom of why the files from this site's converter don't play. Both types play in VLC, neither shows up in mediatab.
Closed Thread
My MP4 player has an actions chip, but that's all I know! andyroorocks20 Support and How To 0 19th Feb 2010 6:48 pm
Dead player HS Actions AQ_2025 not because I upgraded ciasent Support and How To 0 12th Jan 2010 5:04 am
Actions Based - Moserbear Mp3/4 Player tools/firmware? tripad Mods and Themes 1 13th May 2009 12:03 am
NEW actions chip (Actions ATJ2135) - player availability makd511 General Discussion 63 18th Jan 2008 11:38 am
Do you own a recent SRS capable Actions-chipset player? Zaphod General Discussion 5 16th Aug 2007 1:53 pm
