Amv video volume too low....
Old 4th May 2006, 3:46 am
avi
Guest
Posts: n/a
Default Amv video volume too low....
is there a way to amplify the audio volume of a video file before converting it to amv?
or can i do the amplifying in the converter itself?
THANX 8)
Old 4th May 2006, 2:00 pm
Sidh
Guest
Posts: n/a
Default after converting to AMV the vedio plays low volume
Even i have same problem once i convert any vedio file to AMV and play it in the player the volume is very low
I checked the setting in AMV converter tool we have a option for audio but its grayed out
Is there any way so that we can have the original sound
Plz assist
Old 4th May 2006, 3:53 pm
avi
Guest
Posts: n/a
Default Re: Amv video volume too low....
I tried to strip the soundtrack off the video file, and succeeded...
and I amplified the audio volume and with the AMV CONVERTER TOOL, I mixed it into the conversion.. (with the grayed line mentioned here ...)
BUT even after the AMV file sounded much louder in the computer than the original soundtrack, the player was still playing the file, but in a very low volume...
What can I do? :cry:
Old 5th May 2006, 3:11 am
avi,
What happens if you try the sample AMV files from our site? Does it do the same with low volume too?
If you increase the volume of your mpx player to full/maximum, does that help? (thought I would ask)
Old 5th May 2006, 6:58 am
avi
Guest
Posts: n/a
no.
unfortunatly the sample video's volume is to low as well...
and the low volume Im talking about is in the highest volume setting of my MP4 player...
Old 5th May 2006, 5:50 pm
avi,
Humm, the volume of the sample AMV files on our site play quite fine on my players (I have a few). So, this leads me to believe it might be your player.
You can play MP3's fine with the right volume right? Have you tried a different set of headphones/earphones just in case it's not the headphones that's causing this?
Old 7th May 2006, 10:19 pm
I have the same problem. Mp3 are loud and fine, but videos are very very low volume...
Old 9th May 2006, 5:24 am
Guest
Posts: n/a
Old 12th May 2006, 10:35 pm
up
Old 28th May 2006, 6:53 pm
dead_groundhog
Guest
Posts: n/a
I have the same problem. The MP3 playback volume is nice and loud, but when I try to watch an AMV video on the bus or subway I can barely hear anything.
Volume down = volume up? Opirian Support and How To 1 3rd Jan 2008 9:06 am
AMV Volume issues mmginc Video related 5 23rd Feb 2007 11:38 pm
Cannot turn the volume up phpeters87 General Discussion 4 10th Feb 2007 1:03 am
volume??! jaidagr8st Support and How To 1 26th Jan 2007 2:57 am
MP4 Player Volume? Scooper Support and How To 7 4th Jul 2006 3:20 am
