smv problem
Old 4th Jun 2006, 7:28 pm
Guest
Posts: n/a
Default Re: smv problem
relaxxx,
Thanks for that.
For the 1.5” amv you can edit the transform.ini file to 90*
by making this change:
BMPADJUST=4 - Rotate 90 degrees clockwise
BMPADJUST=5 - Rotate 90 degrees counterclockwise
or you can use:
http://www.pocketpcfreewares.com/en/index.php?soft=972 to optimize and rotate before encoding to amv.
Download the sld codec pack( in downloads section) on your win98 machine then try again. Keep in mind that SMV is a relatively new format/codec and may not be optimized legacy platforms (98,98se,ME).
I agree, there is no framerate adjustment in smvtool but I would peg it at appx. 12 fps. You can select 16fps w/ amvtool.
Old 4th Jun 2006, 7:30 pm
relaxxx,
Thanks for that.
or you can use:
Old 6th Jun 2006, 3:47 am
The SLD pack says it’s for XP and gets errors installing on my Win98.
Old 6th Jun 2006, 4:39 am
Iridium
I have the Sigmatel Firmware Extractor. Haven't used it yet though. Trying to find Sunplus Firmware extractor now......
Good luck with the Sigmatel as I haven't played around with that yet....
I will upload the extractor tool shortly.
Thanks for posting your Pros/Cons as well.
The plus side i see with Actions boards is that it's very common and there are tools like s1fwx and s1res which lets you modify the firmware on it. I don't know about the Sigmatel ones though.
Old 9th Jun 2006, 8:49 pm
@ relaxxx,
Google and download :
Media Player Classic
This player has most codecs built in. Try again once you install it. I have never gone back to Windows Media Player.
@ Binh,
I look forward to downloading the Sigmatel Firmware Extractor. I won't have much time to play w/ it until next week tho. I'll let you know if there are any probs w/ it.
  #16 (permalink)
Old 12th Jun 2006, 7:09 am
Robertoy
Guest
Posts: n/a
Default Sigmatel player Main menu
Originally Posted by Iridium";p=&quot View Post
I've just received my 1st Sigmatel player.
Hi Iriduim,
Your Sigmatel player has a Main menu like the model of the link below?
http://www.mympxplayer.com/viewtopic.php?t=98
Best regards,
Roberto
