problems with converting in .amw
Old 8th Jun 2006, 11:56 am
Romik
Guest
Posts: n/a
Default problems with converting in .amw
1) I`ve an interesting problem with amw tools 4.00. When i`m converting video in 128x128 resolution it plays perfectly, but when i`m converting video in 160x120 resolution (to watch full screen video) it start to play and after 5-10 seconds says "format error" ( my mp4 has 1,8" lcd screen).
2)Who knows program to convert video in 160x120 resolution(not amv tools 4.00)? :cry:
I`ll be very glad , if somebody helped me!!! ops: Thanks for yours answers and help!!! (sory for my bad english, i`am from Latvia) :roll:
Old 8th Jun 2006, 2:25 pm
Default Re: problems with converting in .amw
Romik,
This is fairly common, as ver. 4.00 is still a bit unstable.
Simply uninstall 4.00.
Download and install 3.68.
Once installed, in order to obtain 160x128 resolution, you must edit the AmvTransform.ini file. Open it in notepad, and in this string:
VIDEOSIZE=96X64(8;10;12),128X96(8;10;12),128X128(8 ;10;12)
insert 160x128(8;10;12)
reboot, and test. Post back results.
Good luck,
I
Old 8th Jun 2006, 5:28 pm
Guest
Posts: n/a
Romik, I have not been able to convert any .amv files at 160x120 on any version of AMV Conversion Tool and have it play completely without the dreaded "format error" or jerky motion. All other resolutions are fine.
If I find a solution I will let you know.
Old 9th Jun 2006, 5:47 am
Romik
Guest
Posts: n/a
Thanks for help! I`ll try, and will give the results.
Grundig MPixx 4400 converting problems yeshua Video related 6 13th Mar 2009 12:09 pm
Problems converting above 160x120 Metal Martinez Video related 2 1st Mar 2007 5:40 am
having problems converting files tetor Video related 2 16th Jan 2007 10:38 pm
Problems converting XVid to AMV razzer001 Video related 3 3rd Jul 2006 10:30 pm
Problems converting files to amv DaSilva Video related 1 3rd May 2006 2:29 am
