10th Jun 2006, 9:48 pm
antdroide, AMV files are always in mono but you can use a program called PocketDivxEncoder from the download section that will allow you to make adjustments to your video files (sound, brightness, size etc.) before you convert them to AMV.
The quality of the finished product really depends on the quality of the original video
