Problem Upon Conversion To AMV
  #21 (permalink)
Old 15th Jun 2006, 1:25 pm
Hi
Not sure what has happened now but keep getting a DEP whenever i use windows explorer.
I knew i should have left well alone...lol
  #22 (permalink)
Old 15th Jun 2006, 3:48 pm
AGoldenberg,
Whilst the process of converting to AMV could certainly be streamlined I have converted in excess of 100 video files of assorted format in the process of building up a library of AMV's and have had no problems with sound on a single one of them. Not that it is going to help pinpoint the problem, I think it must stem from your PC setup, by this I mean perhaps there is a program conflicting with the converter, a codec issue, I do not know but something within your operating system enviroment. If possible try converting the files on another system and see if the same problem occurs.
  #23 (permalink)
Old 15th Jun 2006, 3:49 pm
angel, Sorry for my ignorance but what do you mean by "DEP".
  #24 (permalink)
Old 17th Jun 2006, 2:01 am
Originally Posted by angel";p=&quot View Post
Hi
Angel,
Can you create a new post for your problem please? This will make it easier to organise the posts.
  #25 (permalink)
Old 17th Jun 2006, 5:38 am
Default Re: Problem Upon Conversion To AMV
SOLVED!!! Hi all
Thanks for your help.
Its all been solved now. just downloaded something dodgy.
Help with avi to asf conversion kimig1 Video related 12 25th Sep 2008 4:19 am
Problem with Anyka Player Video Conversion srac Video related 0 14th Jan 2008 10:30 pm
AMV Conversion Help minto1959 Video related 5 12th Feb 2007 6:22 pm
Help with AMV conversion for the Non Intel Mac Deckar Support and How To 1 9th Feb 2007 6:33 pm
