Problem Upon Conversion To AMV
Old 14th Jun 2006, 8:44 am
Default Problem Upon Conversion To AMV
Hello,
Let me start out by saying great site, fantastic resources glad someone was nice enough to start something like this.
Anyways, when I convert any type of video media to AMV, and put it on my player, the video turns out great, however the audio keeps skipping and sounds aweful.
Is there a fix for this? Maybe a firmware update?
By the way, my player is an IPOD Nano Style Player with the headphone jack at the side with firmware version ACI_V3.5.35
Please let me know if there is something special I need to do.
Old 14th Jun 2006, 9:37 am
AGoldenberg, If you are using version 4.0 of the AMV conversion tool try using 3.68 as 4.0 is a little buggy.
A firmware update is not worth the risk of killing your player, and I doubt if it would help.
You may need to install the codec pack in the Downloads\Tools section if you have not installed one.
Let us know if any of this helps.
Cheers
Old 14th Jun 2006, 10:20 am
Default Re: Problem Upon Conversion To AMV
Hey thanks for the info, can you give me a direct link to the version of converter I need. Also I dunno if I need the codec packs. It seems to convert everything ok. The video plays just the audio is choppy.
Anyways leave me a link and ill check it when I get home. I'm @ work right now and not really free to download/install stuff lol!
Old 14th Jun 2006, 10:43 am
AGoldenberg, God employers can be unreasonable at times.
Here is the link:
http://www.mympxplayer.com/dload.php...file&file_id=2
Re codecs, you may just have a .dll or something that needs updating, I had a few problems initially and ended up installing the K-Lite Mega Codec Pack and have had no issues since.
http://www.free-codecs.com/download/...Codec_Pack.htm
Old 14th Jun 2006, 10:57 am
Tell me about it eh? Can't even attach a USB drive since we deal with social security numbers sometimes.
Anyways thanks I'll check it out when I get home. I am hoping to contribute a theme or 2 once I get on it. Im a graphics designer so it should be easy....I hope
Old 14th Jun 2006, 12:41 pm
AGoldenberg
Welcome to the site.
Question, are all your converted videos have choppy sound? Or only some? If it's only some, then most likely it might be the codec that's not decoding them properly.
I also suggest try AMV Convert Tool 3.68 instead and see how that comes out.
If you can contribute your theme, that would be great! I'm a terrible graphic designer unfort .
Hope that helps.
Old 14th Jun 2006, 12:43 pm
It's on all videos. Every single one of them comes out with choppy audio. It's skips all the time the whole way through.
Old 14th Jun 2006, 1:36 pm
AGoldenberg
Doesn't sound good if it's on all audio then.
Try ver 3.68 of the Convert Tool instead and see if that makes a difference.....
Let us know.
Old 14th Jun 2006, 4:40 pm
Well, I have installed the codec pack and tried 3.68
3.68 has no UI it just shows me a blank screen, and I was unable to continue.
The audio is still choppy and pissing me off.
Someone help me get video working with a fix!
Old 14th Jun 2006, 5:23 pm
Guest
Posts: n/a
AGoldenberg, download some sample AMV files from the download section. If they are the same then the problem is with your player if not then it is a conversion problem on your PC.
Help with avi to asf conversion kimig1 Video related 12 25th Sep 2008 4:19 am
Problem with Anyka Player Video Conversion srac Video related 0 14th Jan 2008 10:30 pm
AMV Conversion Help minto1959 Video related 5 12th Feb 2007 6:22 pm
Help with AMV conversion for the Non Intel Mac Deckar Support and How To 1 9th Feb 2007 6:33 pm
