AMV 4.00 problems
Old 1st Jul 2006, 2:59 am
max2,
The error is due to frame rates. Your players cpu crashes when trying to render full screen video at the High frame rate setting, it just isn't powerful enough. The problem being you can not adjust frame rate at 160x120 in version 4.0 as the settings are default.
If you edit the AmvTransform.ini in the AMV Conversion Tool folder (4.00) and edit CHIPTYPE=1 to CHIPTYPE=0 you will be able to get it to convert 128x128 and adjust the settings.
However if your screen is 1.8 and you want full screen 160x120 you will have to use Version 3.57 as it is the only version that you can adjust the frame rate at this resolution.
I have posted how I did this here http://www.mympxplayer.com/viewtopic.php?t=449
Problems with new mp4 al pal Support and How To 4 5th Nov 2007 5:03 am
MP4 Problems mark2 Dead Players 18 2nd Feb 2007 11:01 pm
Problems with LCD sodiumray Support and How To 0 22nd Dec 2006 8:02 am
problems with vl-547 dp Support and How To 2 25th Sep 2006 10:47 pm
PTA. Has to much problems PTA Video related 5 19th Jul 2006 7:25 am
