-   -   AMV 4.00 problems (http://mympx.org/forum/video-related/33490-amv-4-00-problems.html)
max2 30th Jun 2006 3:38 pm
AMV 4.00 problems
I have just encoded the Lion king using the AMV 4.00 conversion tool which I downloaded from this site. I very pleased with the result in fact I’m amazed at the quality of the movie on this little player.
The encoded video plays back but with black lines at the top and bottom, can the video be encoded so that it players play back in wide screen.
Also the encoded video plays then it freezes and the player becomes inactive, to the point it has to be turned off before I can get back the player to function again. Any suggestions would be appreciated.
tadad1 30th Jun 2006 3:57 pm
max2, Version 4.00 of the software is a bit buggy, I suggest you download version 3.68 which is stable.
Let me know what size screen your player has and I will give you some settings for full screen.
max2 30th Jun 2006 4:00 pm
Let me know what size screen does your player has and I will give you some settings for full screen.
Thanks for your reply the screen size is 1.8
admin 30th Jun 2006 4:42 pm
max2
I agree, ver 4.00 is alittle buggy, best to try ver 3.68 instead.
You can try using PocketDivXEncoder to resize your video to the size you want. It's very easy to you. PocketDivXEncoder can be downloaded under the "Downloads" sectiion on this site as well. It's freeware and requires no installation :).
30th Jun 2006 5:22 pm
Originally Posted by admin";p=&quot (Post 3924)
max2
Thanks admin for your reply, my player use the AMV file converstion, can I still use the PocketDivxEncoder?
tadad1 30th Jun 2006 5:47 pm
Guest, I have a 1.8 as well and had problems with AMV files not playing this is how I managed to overcome the problem.
http://www.mympxplayer.com/viewtopic.php?t=449
Weecho 30th Jun 2006 11:31 pm
I saw in my 1.5 screen that setting it to Middle encoding in amv fixes my amv format error problems.. i guess its too many frames for the player at high.... although some do just fine at high... and im talking movies and such so who knows... Any Thoughts admin or tadad1??
BTW i do use 3.68
..::Weecho::..
max2 1st Jul 2006 2:05 am
Just converted the Lion King with AMV 3.68 and AMV 4.00, and the quality of the converted movie using AMV 4.00 is much better.
AMV 3.68 picture quality is not as sharp it drags and the audio has sync problems, whereas AMV 4.00 playes smoother and the audio quality is like listening to surround sound.
The only fault with AMV 4.00 is it freezes is there anything I can do to overcome this problem?
tadad1 1st Jul 2006 2:15 am
max2, What size are you converting to 128x96 or 160x120.
max2 1st Jul 2006 2:36 am
Thanks tadad1 for your reply, In version 4.00 I have used 120X160 and in 3.68 128X128
