Problems converting XVid to AMV
Old 3rd Jul 2006, 3:09 am
Default Problems converting XVid to AMV
Anyone else have problems converting movies in Xvid format to AMV? I have all the needed codecs and such, i am using AMV converter 3.57 (its more stable than 4.0).
Or do i need to convert it back to a normal AVI file?
:lol:
Old 3rd Jul 2006, 3:35 am
razzer001, are you sure you have xvid and divx codecs installed.
Old 3rd Jul 2006, 10:28 pm
Default Re: Problems converting XVid to AMV
I am having problems too converting xvid to amv.
One movie I tried crashes after a while playback and on another that I tried the playback is unstable.
Framerate ist constant then slows down, faster than slows down somehow a wosh effect.
I think it would be much better converting the xvid file to normal avi mp4 and then to amv format.
Old 3rd Jul 2006, 10:30 pm
razzer001
Have you tried ver 3.68 of the AMV Convert tool instead?
Also, have you tried putting the tick in "user other codec" in the settings of the AMV Convert Tool to see if that helps?
Problems converting above 160x120 Metal Martinez Video related 2 1st Mar 2007 5:40 am
having problems converting files tetor Video related 2 16th Jan 2007 10:38 pm
problems with converting in .amw Romik Video related 3 9th Jun 2006 5:47 am
Problems converting files to amv DaSilva Video related 1 3rd May 2006 2:29 am
How to: Solve problems installing AMV/MTV Converting Tool admin Knowledge Base and FAQ 0 29th Mar 2006 1:04 am
