Problem with AMV_Convert_368
Old 6th Jul 2006, 8:48 pm
Default Problem with AMV_Convert_368
Hello friend i write from Italy,
I have a problem with amv convert 368 dowloaded from your site.
Download and install 3.68.
Once installed, in order to obtain 160x128 resolution, you must edit the AmvTransform.ini file. Open it in notepad, and in this string:
VIDEOSIZE=96X64(8;10;12),128X96(8;10;12),128X128(8 ;10;12)
insert 160x128(8;10;12)
VIDEOSIZE=96X64(8;10;12),128X96(8;10;12),128X128(8 ;10;12),160x128(8;10;12)
The problem is that i can't change into 160*128 becouse i can't see this resolution but only the 3 old.
Thanks and help, help,
Old 6th Jul 2006, 9:25 pm
stefanor, 3.68 will not convert 160x128, you need version 4.0 or version 3.57. I use 3.57 because there is no way to adjust the settings in version 4.0 and the default settings give me Format Errors.
Here is a previous post on the settings I use in 3.57 :arrow: 160x120 AMV without "Format Error"
Old 7th Jul 2006, 1:30 am
Default Re: Problem with AMV_Convert_368
Hello tadad, i had already read your interesting post. Using convert 4 i haven't any problem, my china i-pod read very well the format standard 160*120 at 16 fps. I am serching how convert at 160*128 at 16 fps. I have found the md of the string at 3.68 version. With your mod ad 3.57 i haven't the resolution at 160*128. I hope i have understand. Excuse me for my english.
Hello
Old 7th Jul 2006, 4:08 am
stefanor
If you use AMV Convert Tool 3.57, then read this post by tadad: http://www.mympxplayer.com/viewtopic.php?t=449
Convert a file, then go into your C:\Program Files\MP3 Player Utilities 3.57\AMVTools and look for a fle called transformsetup.ini.
Open up the file using Notepad, then edit the line that says:
VWH=128*96
Change that to the size you want (example: VWH=160*128 instead).
Try that and let me know if that works.
Old 7th Jul 2006, 4:27 am
Thanks a lot boys, hello admin, this is a very good forum, compliments for the rapidity of your answers. Now i am in office, but this evening i will try and after i will report the result.
Thanks and bye
stefanor
Old 7th Jul 2006, 4:34 am
stefanor, 160x128 did not work for me I needed to set it to 160x120 otherwise it defaulted to 96x64.
