A little help
Old 7th Jul 2006, 7:25 am
Default A little help
Hello, I Just want to start with a salute to this great forum,
Very Nice!
I recently bought a "mp4-player" but since I´ve got windows 98 on my computer i can´t convert videos to .amv format and i got this music-video I really want to have on my player Is there any way of getting help with this?
The problem is that I cant install the required windows media player v. 10.
Old 7th Jul 2006, 7:41 am
MrPitch, try installing the K-Lite Mega Codec pack a google search will find it for you. it should contain all the files you need to convert.
Old 8th Jul 2006, 9:55 am
Default Re: A little help
Hi,
Thanks for the tip but it says in the program it cant open before i install windows media player 9.0 or higher. and thats not possible on windows 98 first edition.
Old 8th Jul 2006, 5:44 pm
put WINDOW XP ON UR COMPUTER
Old 8th Jul 2006, 9:34 pm
MrPitch
I suggest upgrading to Windows XP.
Unfort a lot of the tools, drivers and codec packs don't support Win98 anymore. Windows is also withdrawing it's support for Windows 98 very soon as well.
Is there any chance of you upgrading to Windows 2000 or Win XP?
Tools like s1fws and s1res (used for firmware extracting, updating) as well as the AMV Convert Tool all WON'T work on Windows 98 unfortunately. I can't even suggest an emulator or virtual machine as I don't even know of they support Windows 98 as well.
