Lost audio when converting to amv
Old 10th Jul 2006, 12:50 pm
Default Lost audio when converting to amv
I have a 1gb Mp4 player. I downloaded the amove fide converter 4.0 and dried to convert ava files. That didn't work, the program crashed and so I tried mpg files. That converted but it wont play any sound. I downloaded the SL codecs but that hasn't made a difference. Is there anything im missing? I download the sample amv files from here and they played on my mp4 player fine. I had a check and the firmware is 3.5.37
Old 10th Jul 2006, 7:49 pm
minxy, Couple of things that might help you. Version 4.0m is a bit buggy if your player is 1.5 LCD I suggest you use version 3.68. If your LCD is 1.8 try using version 3.57. I posted how to set 3.57 for 160x120 HERE
You could still be having a codec problem as well try installing the K-Lite Mega Codec Pack, a Google search will find it for you.
Hope this helps, let us know if you are still having problems.
I really need help, im really lost bambambigellow Support and How To 3 29th Feb 2008 4:53 am
Can't get audio when converting .mov to .amv ckehayas Video related 2 30th Dec 2007 12:57 am
Lost Firmware for 4GB MP3/MP4 Video Movie Player 4G Audio mikey Dead Players 1 19th Dec 2006 1:09 am
i lost my usb cable. help! otakueric General Discussion 15 7th Dec 2006 11:54 am
Lost Cable Buster General Discussion 5 3rd Jul 2006 5:59 am
