( Solved )Pocketdivxencoder problem
Old 14th Jul 2006, 2:20 am
Default ( Solved )Pocketdivxencoder problem
Hi everyone,
Ive been using a prog called dvd ripper to analyse contents on my dvds, and then ripping to wmv, as a preliminary step before converting to amv. Works perfectly.
My problem is when I rip, a file is created on desktop called VIDEO_TS, which hold the individual wmv files - this is where I extract normally with amv converter with no hassle. However I decided to give pocketdivxencoder a try, but when i choose browse, it sees the desktop folder, but will not see the wmv files contained in it ?? I cant get it to recognise the contents at all ?
Does anyone have any idea why this wont work - is pocketdivx resticted to certain formats?
Si
chipod 1GB 1.5" Screen , Black with matt black silicon cover
Old 14th Jul 2006, 2:26 am
Simonski, Yeah pocketdivx only uses a few file types but I was able to rip .vob files straight off the dvd with it.
Old 14th Jul 2006, 5:08 am
Default Re: Pocketdivxencoder problem
Thanks - thought it was me
May give the vob conversion a go when I get a chance - less long winded I guess ..
Cheers
Si
[solved] Yet another eBay 4GB>2GB MP4 problem Fierce Bad sellers/Blacklist 13 6th Dec 2006 9:14 am
pocketdivxencoder eternboy Video related 1 6th Sep 2006 7:39 am
[solved] BIG Problem lekie Dead Players 3 9th Aug 2006 6:40 am
full screen playback 1.8"screen w/ PocketDivXEncoder ? Iridium General Discussion 3 1st Jun 2006 6:40 am
PocketDivXEncoder Freeware Iridium General Discussion 6 6th May 2006 8:24 am
