-   -   PTA. Has to much problems (http://mympx.org/forum/video-related/33733-pta-has-much-problems.html)
PTA 18th Jul 2006 9:02 am
Hello all,and sorry for my bad english.
I have a Brigmton MP4 player,in the instruction of the player says that it plays MTV. but it isn't true it just plays PTA.And this is the second PTA. player that I have from the warranty.So I have 3 things to say:
1-Why when I play PTA. the audio come 3 seconds forward the video??
I ask this because i had 2 pta.players and tried 3 PTA. converters.
2.The player is a 1.8 the displays with a 262.000 K and OLED thehnology
Can I update my firmware so it plays AMV MTV.???
3-Are there some form that the player plays MTV. o AMV. or some other converter that isn't FILM CRE????? Thanks in advance!!! Ill will answer
tadad1 18th Jul 2006 8:05 pm
PTA, I do not know much about the PTA format or converters. Trying to update the firmware is very risky and depending on your hardware configuration may not work anyway.
The only thing I can suggest you try is pre-processing your video with VirtualDub or PocketDivxEncoder to resize and set frame rate before converting to PTA.
I don't know the specifications of your PC but video conversion is very CPU intense if you have a slower system it may be effecting the conversion as well.
PTA 19th Jul 2006 6:14 am
Re: PTA. Has to much problems
Ohh,yes but one time I downloaded one video in WMV format that played the video 200KBPS and it had 12MB when i've converted it to PTA. the video come up to 120MB so I think that it will not work,my notebook isnt the problem because it has Intel Core Duo 2.16 x2 and 2GB Ram.SO i dont now but THANKS!!!
tadad1 19th Jul 2006 6:32 am
PTA, You are right definatly not you PC with those specs. MTV format has the same problem.
PTA 19th Jul 2006 7:21 am
Yes thanks,you tried to help me thanks,thanks I tried 3 pta. converters
1.Film_Cre in this site 2.Film_Cre of my minidisk 3.New Film_Cre from my mp4 site, but when I buyed my mp4 i Januar 2006 I had the same problem but the warranty of my mp4 gave my one new in april buut has the same problem,in the mp4 says that plays MTV but is a lie just because the PTA. is very similar of MTV. And my player ain't a chinese player so I don't know why this things happens.THANKS
PTA 19th Jul 2006 7:25 am
By the way you've asked what hardware had my mp4 I will say you
OLED 1.8 inch 262.000 displays,512 MB,SIGMATel chip.
