BLAZE MEDIA PRO HELP ME FASTT
Old 18th Jul 2006, 6:05 pm
Pinky
Guest
Posts: n/a
Default BLAZE MEDIA PRO HELP ME FASTT
Hello
I have a qs about LOW DISK SPACE
When I Convert or Add a Logo ON Blaze Media Pro & Then I SAVE IT
It gives me LOW DISK SPACE ERROR
WHy is that?
IS there any solution to Add logo or Convert video & Then SAVE IT
THEN I DONT geT Low DISK SPACE?
I WANT LOGO OR CONVERTED FILE WITH LOW FILE SIZE
PLS HELP ME FAST
Old 18th Jul 2006, 6:28 pm
Pinky, Are you getting Low Disk Space error in Blaze Media Pro or with AMV Converter?
You could try VirtualDub, it has the ability to add a logo to video by selecting the logo filter.
Old 18th Jul 2006, 6:41 pm
Guest
Posts: n/a
IM getting on Blaze Media Pro
When i add logo & save the file then on my system bat LOW DISK SPACE message appears
& I did use VirtualDub But it doesnt OPen WMV File
Old 18th Jul 2006, 7:58 pm
Pinky, How much diskspace do you have free? Video editing and conversion can be very hungry as far a disk space is concerned as it generally uses uncompressed data prior to recoding. I am no familiar with the program but some require you to set a maximum disk and ram usage quota. Try checking preferences or settings.
All my media has been wiped??? Masteradam13 Support and How To 2 31st Jul 2008 1:32 am
How to convert Real Media to AMV ? gdrago Video related 1 5th Feb 2007 11:52 pm
Media Maker Homse Support and How To 3 2nd Feb 2007 4:53 am
Media listing felipemv Support and How To 2 9th Jun 2006 2:43 am
Media Manager gman34 General Discussion 4 29th May 2006 4:38 am
