AMV files with low audio bps sequence
Old 21st Jul 2006, 2:56 pm
Default AMV files with low audio bps sequence
So My problem with converting videos to amv files is the next:
In AMV Convert tools at the settings of the conversiation, it is unable to change the bps (the frequence) of the audio part of the video.
I enclose a picture and I point what Im talking about:
[img]c:\AMV problem.bmp[/img]
So what can I do?????
I think it will works, it have to because the mp3 files, and the radio sounds perfect. The videos with this conversion....
The picture is perfect, but ther is any possibility to change the audio better, or kept the same audio quality like the original video file, I cant belive it....
Please advise me something! What can I do! What do I wrong?
Changing audio bps on output *.AMV files harry_pouter Video related 3 23rd Jan 2007 8:53 am
Moving audio files mjasgt Support and How To 0 9th Nov 2006 9:15 am
what Audio Files supported? prasanna Support and How To 9 6th Jul 2006 2:55 pm
Sorting audio files into menus on ipod like player Justin77 Support and How To 0 3rd May 2006 11:33 pm
[solved] Cant Play some Audio Files.... Rillee Support and How To 3 27th Apr 2006 7:06 am
