AMV problems - low audio bps - the image to help to understa
Old 21st Jul 2006, 3:26 pm
Default AMV problems - low audio bps - the image to help to understa
Plese help me! How can I change it, for a good quality audio part of my amv files! ????
Old 21st Jul 2006, 8:37 pm
Csaba, There is no way to adjust the audio in the AMV Converter it is set at a default 22k mono. The quality of the finished product is generally based on the quality of the original file. If you are getting real terrible audio you may have a codec problem. If you want to improve the volume say you need to pre-process your video through PocketDivxConverter or VirtualDub or something and increase the volume before converting to AMV.
Old 21st Jul 2006, 10:06 pm
Guest
Posts: n/a
Default Re: AMV problems - low audio bps - the image to help to unde
But Isee in the AMV Tool 4.00 there is 88k,
But i dont understand why, then it is a very week video file. MP3-s perfect, then I dont understand why arent the sellers, the programmers make a format with good audio quality possibility. (min 44K, 128 kbs). I think it i a big trap. I purchased the player MP4 digital player....
But it wont play mp4, which has a good audio quality, then plays amv, with reduced audio. And there is no possibility to convert tha same video file (WITH HIGH QUALITY SOUND) to amv with the minimum requaired audio standard 128 kbs. There is the option in settings, but it greyed, so it cannot change. And I think this is direct! I will buy somthing better in the future, a sony, or other wich realy can play mp4. I tried what you said PocketDvixEnc. but the amv is louder, but the sound the quality of this soundwave is bad, its not clear becuse of the reduced KH. I dont know what to do, There isnt any possibility to get a cracked AMV Tool from somwhere, in which this option is not greyd?
Thank You for Your kindness, and for the quick answer.
Old 21st Jul 2006, 10:15 pm
If you want to spend three or four times as much, you will get the better sound quality, and more playable options. Try to make the best out of your player. I have never had sound problems with mine. Sure its not dolby digital surround sound but for a portable compact unit, it does the job.
Old 21st Jul 2006, 10:54 pm
Guest, Despite version 4.03 displaying 88k the converted file is only 22k. To be honest I have had no problems with AMV sound quality I find all of my movie conversions to be pretty good. I have seen posts of people having problems with sound on WMV files but I convert all my video to AVI before converting to AMV. As Dansvob pointed out for the price these players are pretty good performers. The other thing you may need to do is buy a better set of headphones as the ones that come with the players are pretty ordinary.
There are players that also play other formats like SMV, MTV, PTA that are supposedly better quality but there file size after conversion can be extremely large and in most cases larger than the original file.
Sorry that you are not getting the results you want, I suggest you download some of the music video samples in the Download section and try them to see if they sound any better than the ones you are converting. This way you will know if the problem is with your conversion of with the player quality.
Old 22nd Jul 2006, 1:11 am
Guest
Posts: n/a
Thank You to try solve my problem, I trying to convert with suggested PocketDvxEnc. and now the sound better, but I have a quation....
Is it possible to refresh my player with a firmver with wich I can play MTV video files. If it is bigger than bigger. but when it has a better sound quality than lets do it... So could anyone advice me a firmware to refresh my MP4 digital player (Nano Clone - Lisong LSD-501-02 SDK: v. 3.5.37) to play other video format than AMV. For examp.: MTV, or MP4, or MPG, AVI, or other wich has a perfect sound quality in stereo.
I wait for the helpful answer! And I thank all of You to try to help me
Thank You very much!
rotate image rodogg Video related 4 5th Aug 2007 7:58 pm
Audio Jack problems sanseven Support and How To 1 18th Apr 2007 11:57 am
this image soliman Dead Players 0 18th Feb 2007 1:51 pm
Inversed Image jmparro1 Support and How To 2 22nd Nov 2006 3:31 pm
Mirror Image dmuk20 Video related 4 26th Oct 2006 5:29 am
