Sound becomes low and weak when converting vob to amv.
Old 31st Jul 2006, 9:03 am
Default Sound becomes low and weak when converting vob to amv.
Can anyone tell me why the quality of sound becomes weak when I´m convertin movie straight from dvd (vob) to amv?
If I´m comverting it first to AVI and then to amv the sound is fine.
Old 31st Jul 2006, 5:15 pm
Kapusiini, It could be a codec problem, what codec pack do you have installed?
Old 2nd Aug 2006, 7:15 am
Problem solved!
I noticed that sound becomes weak and low if I´m converting amv straight from dvd but if I first transfer vob files to my computer and then convert them top amv everytyhing´s fine.
Old 2nd Sep 2006, 8:29 pm
Default Re: Sound becomes low and weak when converting vob to amv.
Kapusiini,
can you tell me how you convert .vob to amv? i try using the AMV utilities converter and it gives me error. thx
Old 3rd Sep 2006, 2:56 am
i converted vob into amv and the sound is still very low on maximum volume setting. anyone got any ideas?
i'm using amv tool 4.00 setting on 128x128, high , high, mode 2.
thx
Old 3rd Sep 2006, 8:39 am
eternboy, I had the same problem when I first started converting vobs and fixed it by installing the K-Lite Mega Codec pack HERE. I now convert all my vob and dvd files to .avi before converting to AMV as it improves the quality of the video.
(Partially fixed) Converting AVI to AMV, no sound/lous static noise UnknownStory Video related 2 25th Oct 2009 12:57 am
Converting and Splitting + increasing Sound afzal Video related 3 8th Dec 2007 7:06 am
Converting to AMV and some has no sound arucart Video related 3 21st Aug 2007 7:05 am
converting from avi to amv, lose video but sound is ok Willias Video related 3 30th Mar 2007 6:28 am
picture is bad and the sound is very weak Laske Video related 1 20th Sep 2006 4:44 am
