Convert a dvd problem
Old 11th Sep 2006, 7:16 am
Default Convert a dvd problem
I try to convert a dvd movie using the Mp3 player utilities 3.68 (also 4.x), but the result file only contains first couple minutes. The source is about 1.5 hours long.
Am I missing something on the setting?
Help!!!
Thanks in advance.
Old 11th Sep 2006, 4:07 pm
Default Re: Convert a dvd problem
vcllvc, Try using something like xMpeg HERE to convert the dvd to .avi first.
Old 14th Sep 2006, 3:46 am
I haven't downloaded it yet but you can really convert your DVD movies to .avi?!!!!
That's the most wonderful news I've heard all day!
Problem trying to convert DVD to AMV eee Video related 1 26th Dec 2007 1:01 am
AMV Convert problem [Solved] amadeus Support and How To 3 14th Sep 2006 11:37 pm
convert DVD problem using 4.03 vcllvc Support and How To 2 2nd Aug 2006 4:24 am
[solved] Problem with AMV convertor - can't convert files Tina Video related 5 1st Jul 2006 9:09 am
AMV Convert will not convert files, crashes Kosh Video related 5 13th Jun 2006 9:00 am
