One very unique 160x120 problem with 4.03
Old 14th Sep 2006, 6:57 pm
Default One very unique 160x120 problem with 4.03
As I understand 4.03 is supposed to let me make 160x120 @16fps videos, but for some reason it keeps producing 176x128 @16fps !!?? Any ideas that might help? Why 4.03 lacks a lot of options from 3.68?? btw I never successfully made 160x120 with any program version...
Old 14th Sep 2006, 7:57 pm
Default Re: One very unique 160x120 problem with 4.03
veggen, It is a bug with 4.03, I use 3.57 for 160x120 setup is explained in this post HERE
Old 15th Sep 2006, 3:26 am
hmmm... I tried 4.0 and it seems to work, but the image is not whole but seems to be tipped at the top and the bottom... is this normal??
can i somehow correct this and still get 160x120?
Old 15th Sep 2006, 3:56 am
veggen, Sorry I do not understand when you say tipped at the top and bottom. Can you upload a short sample and leave a link so I can check it out.
Old 15th Sep 2006, 5:53 am
Here, I used clock.avi found in my Windows folder for this test...
This is how it look in 128x128:
and this is 160x120:
The top and bottom can't be seen...
I guess it is normal for non-proportional image size but I'm not sure...
Thanks a lot!!
AMV mod for 160x120 evans62 General Discussion 0 7th Nov 2007 5:19 pm
avm converter 160x120 lionblazeo Video related 0 8th Mar 2007 5:30 pm
Problems converting above 160x120 Metal Martinez Video related 2 1st Mar 2007 5:40 am
160X120 Is That Possible Edwin Video related 5 21st Dec 2006 9:20 am
Will AMV Converter 4.07 do anything smaller than 160x120? jsevinsk Video related 1 20th Dec 2006 3:00 pm
