[solved] converter will not convert mpg format
Old 24th Nov 2006, 5:51 am
Default [solved] converter will not convert mpg format
Downloaded a Family Guy episode off of lime wire,,, in mpg format, video converter that came with MP4 player will not convert to amv any ideas??
thnks
Old 24th Nov 2006, 8:12 am
Default Re: video file converter tool
install this k-lite (click me) then when u convert using the software that came with your player go to settings and tick the box labeled try other codec
Old 24th Nov 2006, 11:12 am
another solved situation from this board
am I making this too easy or am I that new,, anyhow thanks again for the help
Old 24th Nov 2006, 12:26 pm
Default Re: [solved] converter will not convert mpg format
what player have u got
Old 24th Nov 2006, 3:28 pm
pearlpurple, LOL I think you may need to get yourself a player as well so your son can have a turn
How to convert videos to MPEG4 (avi) format? Invalid format? makenna29 Video related 2 19th Feb 2009 1:25 am
easytech mp4 player converter software fails on convert macky941 Video related 2 1st Dec 2008 10:39 am
[solved] format error/wrong video format... isaac556 Support and How To 2 6th Sep 2008 7:14 pm
Best Program to convert to MTV format DynaMight Video related 5 31st Dec 2007 9:56 pm
[SOLVED] AMV Convert Tool doesn't convert avionik99 Support and How To 2 20th Nov 2006 9:30 am
