tadat1 I need your help
Old 8th Dec 2006, 11:42 am
Default tadat1 I need your help
Hello
Tadad1
I have converted the videos with Virtual Dub and your settings
BUT:
The qualiti isnt as good as when i convert it only with utilies 3.57
where can i make the qualitiy better?
Old 8th Dec 2006, 2:43 pm
blubergeist, I do not recall what settings I sent you but I may have included audio and video compression in order to keep the file size down. I personally do not use any compression in VirtualDub and find I get excellent results so you could try removing any compression settings.
