Problem converting AMV to 160x128 resolution!
  #21 (permalink)
Old 27th Dec 2006, 11:36 pm
tonypisa, Did your player come with a sample video, if so can you upload it and leave a link.
The reason the sound is lost on the sample is because it is not a completed conversion I just ran it for a few seconds and then stopped it.
Can you give me some details on your player:
Capacity
Firmware version
Screen size
  #22 (permalink)
Old 29th Dec 2006, 2:35 am
Capacity
Firmware version
Screen size
Hello Tadad, Thanks for all the help.
As mentioned in another post, the only video that works is one that came with the unit (160*120 @16fps). It can be found here: http://rapidshare.com/files/9166575/original.amv (Actually it is a cute xmas video).
The s1fx program gives this read out:
ic version = 0x0101
storage info = 0x0106, 0x0000, 0x0000, 0x0000
device = 'S1 Mp3 Player'
bootflash type = 'F641'
brom version = 3.0.00
firmware version = 3.5.37
read boot record...
detect firmware size....
firmware size = 0x0077FE00
The unit is 1.8 in, 2GB and made by Sage human electronics and marked model V12. I have filled the player up to 2 GB , and the last mp3 file play fine, so I don't think it is hacked. It is really weird .
Just added a pic:
Thanks again.
  #23 (permalink)
Old 29th Dec 2006, 3:40 am
tonypisa, Can't find any problems with the info you have given and the sample seems quite standard. It may be an idea to give your player a Fat format if you can just to rule out any bad sector or memory problems.
Also extracting, repairing and reloading the firmware can sometimes help, but if you can play the sample no probs i doubt this would make any difference.
I have done another sample for you but this time I have pre-processed the video and resized, reset the frame rate etc prior to converting it to AMV.
http://uploaded.to/?id=a9afae
  #24 (permalink)
Old 29th Dec 2006, 5:55 am
@tad
Tried this one and same thing. Meantime, I found a fellow on an Italian forum that has the same problem and stumbled across something even stranger. If I stop the video before it dies (within 12 sec), and start again, it will go for another 12 sec. In theory I could watch the whole thing about 10 sec at a time, stopping and starting. Weirder and weirder...
Am wondering whether to try and format and/or flash it, but I would rather change it if I can get the ebayer to agree.
  #25 (permalink)
Old 29th Dec 2006, 6:15 am
tonypisa, Go into the movie player and press the menu button, scroll down to "Repeat" and make sure it is set to "Normal".
It sounds like it may be set to "Intro"
  #26 (permalink)
Old 29th Dec 2006, 6:27 am
Damn damn damn - that's it! Never thought it would eve havve that sort of option! Boy do I feel stupid!
A million thanks.
  #27 (permalink)
Old 29th Dec 2006, 6:31 am
tonypisa, LOL , I should have thought about it earlier, just glad that was the problem as it was bugging me big time.
  #28 (permalink)
Old 29th Dec 2006, 6:48 am
I found at least two other people with the same problem on other sites. Sure wuold help if these devices came with a decent manual. Mine doesn't even mention video!!
I'll see if I can write one after I get to know thew unit better. Thanks again.
What resolution do you set converting to AMV for 1.8" s abombaci General Discussion 1 27th May 2009 12:38 am
AVI converter 3.0 resolution problem....... chaoscreater Video related 7 13th May 2007 10:04 pm
converting problem abisi1 Video related 1 8th Nov 2006 10:33 am
converting amv has become problem gnanesh Support and How To 2 24th Sep 2006 8:01 am
[solved] Problem converting music files Lp_Lauj Support and How To 11 5th Jun 2006 10:21 am
