Help!Problem with amv converter tool 4.07 in Italian!
Old 1st Jan 2007, 11:09 am
Default Help!Problem with amv converter tool 4.07 in Italian!
Scusatemi se scrivo in italiano ma non parlo molto bene l'inglese.
Io ho il seguente problema:
Quando converto un film in amv per il mio ipod clone 1.8 con il "amv converter tool 4.07 " i film risultano essere a scatti e non fluidi.
eppure ho istallato windows media player 11 e K-lite codec pack
Dove è il problema?
Wher is the problem? :roll:
Grazie!
Old 1st Jan 2007, 2:40 pm
Default Re: Help!Problem with amv converter tool 4.07 in Italian!
I have the following problem: When I convert a film in amv for mine ipod clone 1,8 with the “amv converter tool 4,07” the films turn out to be in jerks and it is not fluid.
I have windows media player 11 and K-LITE codec pack.
This problem understood to me also with the following versions of amv converter tool: 3.57 , 3.68 , 4.00 , 4,07
how I can resolve the problem? thanks! :?: :?: :?:
Old 1st Jan 2007, 10:34 pm
MPx-a-lolics Anonymous
if the file is in avi, right click on it and see the properties.
if it is 29fps, use the medium fps setting while converting.
if it is 25 fps, use the high/low fps setting while converting.
if problem persist, follow this GUIDE
Old 3rd Jan 2007, 1:03 pm
But because I succeed to only convert the files video in amv (medium quality) with amv converter tool 3,57, but with the new :cry: versions not?
Old 3rd Jan 2007, 2:51 pm
dovesimone, the 4.03, 4.05 and 4.07 versions were released for players with 2.0 inch + screens. Although they have a setting for 160x120 they really convert to 176x128. Although as you have found they do play on some 1.8 LCD players they tend to overload the CPU which causes the jerky playback.
Will AMV converter tool work with Vista? gmiguel Video related 1 19th Jul 2008 1:51 pm
Problem with AVI Converter soybeto Support and How To 1 19th Dec 2007 7:53 pm
smv files/converter problem elf17 Video related 1 10th Aug 2007 8:22 am
AMV Converter Problem grimlockwheelie Support and How To 0 8th Apr 2007 10:11 am
MP4 1.5" 1Gb ITALIAN Correct Language Firmware... fakiro General Discussion 4 3rd Jul 2006 8:04 am
