-   -   Sound and AMV Trouble (http://mympx.org/forum/video-related/35783-sound-amv-trouble.html)
wweontnn 1st Jan 2007 5:56 pm
I got a Xi (Chinese) 4GB mp4 player and noticed that the sound when putting mp3s on it is garbled, or has blips in it when played. What do I do to change this or what mp3 setting do i need to play fine.
Also i can not change the quality setting when converting to amv format and therefore can't play amv files without getting a error.
lddrizzt1 1st Jan 2007 10:05 pm
Re: Sound and AMV Trouble
Most likely your player isn't actually a 4GB player. It might have hacked memory to make it look like 4GB.
You should follow this guide to find out your true memory. Get the guide here: Guide
After you do this it will tell you the true size of your memory. Then your music and most likely your video will run properly.
