avi converter problems for rockchip player
Old 7th Jan 2007, 6:05 am
Default avi converter problems for rockchip player
i recently bought a 2.5" screen UNIBIT X-811 mp4 player... details see link http://www.unibit.com.cn/eproducts_show.asp?id=164
the software disc it came with was corrupt but downloaded the program suggested... avconverter1.0 and latest versions i could find aviconverter2.0 and aviconverter2.1, but although the files created are shown on the player an error message appears when i try to play back. i noticed that the resolution of these programs are 220*176 and my player is 320*240.
help is much much much appreciated.
Old 7th Jan 2007, 6:22 am
gmaster, There is a version 3.0 that converts to 320x240 but I have only found it in Chinese.
http://translate.google.com/translat...lr%3D%26sa%3DG
Old 7th Jan 2007, 1:09 pm
Default Re: avi converter problems for rockchip player
gnmaster
I have written a tutorial on how to convert video for rockchip players. You can select the resolution sizes so it works with all size players. You can get it here
http://www.mympxplayer.org/how-to-vt3183.html
It has worked for everyone thats used so far.
Dave
Finally I found the AV converter for rockchip player perroam0r Video related 7 30th Mar 2008 5:55 am
Problems with amv-converter and player Meinolf2 Video related 3 30th Sep 2007 3:54 am
AVI Converter problems Buzzygirl Video related 13 26th Sep 2007 5:47 pm
Problems with source target in AVI Converter for Rockchip tiawan tim Video related 2 25th Aug 2007 3:54 am
AMV Converter 4.03 problems avvalex Video related 1 19th Jul 2006 3:46 am
