Changing audio bps on output *.AMV files
Old 13th Jan 2007, 9:27 pm
Default Changing audio bps on output *.AMV files
Hello everybody
I'm getting no trouble in converting video files into amv files, and they look just fine in my mp4; however, the audio quality (and as specified in the AMV Convert tool) is configured at 22kbps, hopefully 88 in 4,09, resulting in lousy video files audio playback... Is there a way to rise the bps of the audio part of the amv files???
I'd really appreciate an answer...
Greetings
Old 14th Jan 2007, 10:13 am
Hi again
I've found a supposedly easy to use program which is called "Amv Studio"... it's a less than 10 mb download and you can get it at www.download.com
However, I can't get this software to work; maybe it's just me so I'd like to see if somebody can check it out and tell me if he/she could actually raise the audio quality of AMVs...
Thank you
Old 21st Jan 2007, 1:58 pm
Default Re: Changing audio bps on output *.AMV files
hi,
i was also was about to ask that same question on the forum but eventually i've found an alternative to increase volume on the converted video. what i did, before converting the file is that i made a .wav of the entire video by using a audio converter and setting it to 4800 instead of the standard 1411. once you have that, go to the advance settings and select "insert wav if not enough... " then just add the audio file to the conversion. if your going to a dvd rip, just make a wav file of the avi. hope this helps in some way. it worked for me. but of course, your video will increase a bit.
Old 23rd Jan 2007, 8:53 am
send a blank email to amvstudio@cals-cool-stuff.co.uk and you will get your serial number in minutes.
Moving audio files mjasgt Support and How To 0 9th Nov 2006 9:15 am
AMV files with low audio bps sequence Csaba Video related 0 21st Jul 2006 2:56 pm
what Audio Files supported? prasanna Support and How To 9 6th Jul 2006 2:55 pm
Sorting audio files into menus on ipod like player Justin77 Support and How To 0 3rd May 2006 11:33 pm
[solved] Cant Play some Audio Files.... Rillee Support and How To 3 27th Apr 2006 7:06 am
