need help with amv filed format error
Old 18th Jan 2007, 3:04 am
Default need help with amv filed format error
i need help with this i have a 1.5 inch 4gb and i tried v.3.68 , 3.78 , 4.00
i dont know which one to use so if i can get some help thnx and i'm new here just regestered like 10 mins ago
it keeps on saying format error but the video is about to start and it says format error
Old 18th Jan 2007, 4:45 am
lorijuan1024, Currently these players only support a max of 2GB memory so your players memory has been manipulated so that it reads a 4GB but in fact is much smaller. To check this you can use the MP3 Player Disk Utility as posted here:
http://www.mympxplayer.org/feedback-...rs-vt2828.html
To fix your problem you need to remove the memory hack so that the chip reads its true size, to do this you can use this guide.
http://www.mympxplayer.org/how-to-re...236.html#19236
Once your memory is reading it's true size you should not have any problems.
Old 18th Jan 2007, 10:35 am
yea i have a hacked player it has 961MB
[HOWTO] Remove DISK ERROR! / Error format etc.. on AK2025 Errorboy Support and How To 16 30th Jan 2010 3:28 pm
Format error help. stupid.freshman Support and How To 9 5th Jan 2010 4:50 pm
[solved] format error/wrong video format... isaac556 Support and How To 2 6th Sep 2008 7:14 pm
Filed complaint with BBB against Paypal bigchat1 Bad sellers/Blacklist 5 13th Feb 2007 9:34 pm
Format error ! of AMV files and error in copying in the exes satish Video related 2 2nd Oct 2006 7:11 pm
