A little problem on my Glacier
Hello!
I'm trying to view a "Simpsons" episode on my player, and I encoded with 220x176 and "best" quality, but when I play the episode on my player, sometimes it stops and repeats the sound, not playing the file "smoothly", it just keeps bumping, I can't explain this better because my English vocabulary is not that great... Thanks. |
Masterwork, What version of MP3 Player Utilities are you using?
4.0.5
I tried the same video, with 220x176, with "high", "medium" and "low" or something like that, and the same problems happen at the same time :| |
Masterwork, Are you sure you are using 220x176, my version of 4.03, 4.05, 4.07, and 4.09 only go as high as 208x176.
Have you tried encoding other sizes to see if you have the same problem? |
You're right, my bad, it's 208x176
I haven't tried other sizes, because this one is the only that fits totally on my screen. |
Masterwork, 208x176 and 208x160 give a frame rate of 10fps, I found 208x144 gave a better video because the frame rate is 12fps and much smoother.
The same problems keep happening, but when I view the .amv on my computer it's perfectly fine...
Masterwork, Try formating the player in Fat format.
I did and the same problem keeps happening... Maybe it's something with the .avi? But it can't be because the .amv works just fine on the computer... I'm totally clueless
Masterwork, Do you have a codec pack installed? If not try using the K-Lite mega Codec Pack here:
http://www.free-codecs.com/download_...hp?d=2879&s=42 Try some other video files to see if it is a problem with the .AVI's Failing that there may be a problem with your player. What size memory is your Glacier? |
| All times are GMT -7. The time now is 8:10 pm. |
