Battery
Old 5th Feb 2007, 4:16 am
Default Battery
[color=#][/color]
I have a problem with my Zling Niki V2, Can the light be switch off while i playing my music? Because the battery used very fast... if anyone know how... Pls reply me... Thz
Old 5th Feb 2007, 4:55 am
MPx-a-lolics Anonymous
after searching, i saw a picture of zling niki and it looks like a normal mp4 player. so try this
1. go to settings/system setup/system, then go to lcd and choose the 'black' option and then you can move the slider right and set the number of seconds after which you want the light to go off on the screen.
2. another thing you could do to save battery is decrease the brightness/contrast which is again there in settings=>lcd set
3. and last thing is that for swtiching of your player, you should switch off using the plastic switch like thing on top/side of the player after switching the player off using the play button.
need new battery moneybankz Dead Players 0 20th May 2008 1:07 pm
ME2 Mp3 Mp4 Battery gloriaharvey Support and How To 4 6th Nov 2007 11:13 am
Take out battery KingGinola Support and How To 7 17th Feb 2007 9:27 am
battery katana General Discussion 5 24th Dec 2006 5:07 am
Battery Sua General Discussion 8 29th Nov 2006 7:21 pm
